write and read boolean data
i have wrriten a simple program, which compares two numeric values. when we run the program , it compares the valurs , anf if they are equal than the boolean indicator goes to green, and visaversa. I want to read the boolean out put that is on/off  to message. hoe can i convert the boolean value to text?
(4,917 Views)
use the boolean to (0,1) it is under numeric and than conversion on the block diagram:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,914 Views)
simple example:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,913 Views)
this one goes to text:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,912 Views)
here is a better example:
hope this helps
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,877 Views)
If you simply want to pick between two strings depending on the boolean, you can do one of the following:
Message Edited by altenbach on 05-15-2009 12:43 AM
(4,869 Views)
Since he's using an "LED", if the Boolean Text is on, this is a very easy way to do it.
Richard
(4,850 Views)
