write PNG file
Hi Fred,
have you tried it? It's a snippet!
You get an array of file paths...
Message 21 of 38
(1,538 Views)
For some reason, I can't drag the snippet into my block diagram. Okay so it retrieves all the png images in the folder that I specify so is there any way for me to display all the png images that I retrieve on a indicator?
Message 22 of 38
(1,533 Views)
Hi Fred,
"to display all the png images ... on a indicator?"
Yes, there is a way...
One after the other: FOR loop with autoindexing (and maybe a small wait for each iteration)
All together: Look at the examples for the picture indicator. Then "append" the pictures to build a big one...
For the snippets: searching the forum may help...
Message 23 of 38
(1,531 Views)
To be more exact can I display them one after another on a picture ring? This is because I need these images to create an animation.
Message 24 of 38
(1,524 Views)
Hi Fred,
I'm afraid there is no property to set the images in a picture ring at runtime - atleast I did not find one in a quick search...
So you have to use a picture indicator - you still can show the pics as an animation.
Have you searched the forum for "animated gifs" or like?
Do you get the point on continuing in this thread? "All information in one place"...
You ask something, I provide an answer. You ask again and provide more details of your first question.
Maybe you should learn to ask with providing all neccessary information in the first place?
Message 25 of 38
(1,521 Views)
Hi Fred,
About your snippet issue. Have you saved the snippet on your hard drive before dragging it or have you just tried to drag it directly from the forum?
Otherwise, the snippet is in 2009 version, so you can open it with any LabVIEW version from 2009. Wich version of LabVIEW are you using?
Olivier L. | Certified LabVIEW Developer
Message 26 of 38
(1,517 Views)
You said that it was possibe to display all the png images one after another on a indicator. After trying for some time, I still counldn't achieve it. Could u give me some idea on how to do it?
Thanks.
Message 27 of 38
(1,503 Views)
Hi Fred,
it's the same as showing one pciture, but with a loop around it:
Message 28 of 38
(1,501 Views)
For the snippet, I just drag it directly from the forum and I am using LabVIEW 2009.
Message 29 of 38
(1,472 Views)
Hi. I connected according to your snippet but when I run it, the VI generated an error ( Screenshot below).
So may I know what are the possible causes of this error?
Thanks.
Message 30 of 38
(1,471 Views)
