write 2D array data into file but file is empty
I tried to write all data reading from powermeter into a file in two ways, I can see the output data in the Indicator Arrais but when I write to "Spreadsheet file.vi" or write to "text file", the files are empty.
Please help me.
(2,838 Views)
Accepted by topic author sam009
Try removing the "STOP" vi.
I suspect it is stopping the main vi before the saving occours.
As a second comment: since you save data inside a while loop make sure you are appending data to the file and not overwriting it each time.
i.e. wire a "true" to "append to file" terminal.
Marco
(2,835 Views)
Dear Marco,
I removed the "STOP" vi. and worked. Many thanks.
(2,830 Views)
