write 16 chennel data in one spread sheet
hello,
         I have a device with 16 load cells and I control the device with labview7.1. When I run my program my o/p is 16 arrays and I want to write the data as each load cell data in each coloum. I am not able to do that as  I am able to connect only one channel to the write function. I used merge signals function and run the VI my data looks  so weird. I would really  appreciate if some could help me.
deepthi krishnamaneni
(2,789 Views)
Hi Deepthi,
Plz tell me if i have not understood your query correctly.
You want to write data coming from 16 load cells.( I assume you are acquiring by running a  suitable AI program that gives 16 cahnnel data in form of a 2D array).
In the attached VI, i have shown 2 methods for  writing a 16 row 2D array to spread sheet file.
Hope it helps.
regards
Dev
(2,781 Views)
hi dev
        thanks a lot for helping me. That was helpful for me. I think my question was kind a silly to u but I just started leanning labview thats the reason I have all kinds of wierd doubts in my mind.
   Actually I have another question dev. I have two for loops in my VI. The VI should run in such a way that first loop should run then I need to get a flash signal saying that the loop had end and then i need a start button to sart the second "for loop".
It would be really helpful if u can reply .
thanking you for your help
deepthi
(2,757 Views)
Hi Deepthi,
Your questions can be solved in many ways, I have demonstrated one of them. Find the vi attached.
(2,750 Views)
Hi Deepthi,
Hope you enjoy learning Labview.
Its kinda fun programming in labview coz, u get to be more creative 😉
Do not hesitate to clarify any doubt you have, no doubt is silly while you are learning.
Look at attached VI , hope it  suit your specs for running 2 for loops.
I have used Events in this Vi , read about them here
all the best
regards
Dev
(2,747 Views)
