with out button press .event should occur once
Hi is it possible to trigger the event when we run the program with out pressing any buttons in the code
Message 1 of 15
(3,875 Views)
Use the property node "value.signaling".
Message 2 of 15
(3,874 Views)
Hi i am not clear for which property node of button or which one make me clear.Thanks you ya
Message 3 of 15
(3,869 Views)
  • First you need to create a "value change" event for a control.
  • Now right-click on the control and "create... property node... value(signaling)"
  • Whenever you write a value to the signaling property, the "value change" event associated to the control will fire (even if the new value is the same as the old value).
Please let us know if this is still not clear.
Message 4 of 15
(3,858 Views)
OK, if you want to execute the main event once at program start, you can use one of the two techniques shown in this old post.
Message Edited by altenbach on 09-22-2008 12:05 AM
Message 5 of 15
(3,850 Views)
Thank a lot ya it is working
Message 6 of 15
(3,845 Views)
Hi it is working fine for all type of button But not working for square shape OK button
Message 7 of 15
(3,809 Views)
Check the Mechanical Action of that button. If it has Latching Action, then Val(Sig) wont work. Smiley Sad
You can visually easily check the Mech Action of a button from its Val(Sig) property node. Smiley Wink
If the color is green, then it has Switching action; if the color is purple, then it has Latching action. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 15
(3,801 Views)
I need it for latching action button.kindly help me out
Message 9 of 15
(3,795 Views)
In the event case "value change", for the button, write it to false.
That will simulate the latching action.
Message 10 of 15
(3,792 Views)
