wiring inputs n outputs for case structure
Hi Altenbach....
That's a really amazing.Now, I know that labview is easy....I think that I gain a knowledge more and more.Thank u very much...
Now, I try to follow ur programming'  just like that.but i think that I have some problem there.1stly,refer to my string.vi below,when I place the spreadsheet string to array here, it built with 2d array at array type.so I just put an index array and wire to the array output.It is correct?.And the other prob is when I try to save data.It seems like sometimes it can write file to text n sometimes it won't.Can u tell me where I'm wrong here.
Then I'll try to rebuild it in my application (interface with my hardware).Refer to the image below.It seems like it can show in one row only and not run consequently to next rows...I don't know why.but the method is same as string.vi before...And how to save data that it will write data into file with one second or minute per data.Because if I want to run this prog over 1 hour or day, I need to reduce in one minute per data to make sure that the file did not exceed 100M or else in my hard disk....Thank U very muchSmiley Happy
Message 11 of 12
(482 Views)
Message 12 of 12
(462 Views)
