winpcap send packet
Hi
I am looking for any updates on how best to send mac level packets from labview.
I have found:
http://zone.ni.com/devzone/cda/epd/p/id/2660
and
http://forums.ni.com/t5/LabVIEW/WinPCAP-for-LabView-v-0-1-alpha/m-p/343479/highlight/true#M175885
both of which are quite old.
The first works fine for reading packets but does not include the send function.
The second does include a send, in version 0_6, but seems to send the packet data in hex strings which are a little awkward.
Is this still the best way to send such packets?
David
Message 1 of 8
(6,335 Views)
TCP packets are just bytes. The format of teh data depends on what protocol you will be using. You wil need to format the packets according to the protocol specification for what you are doing.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(6,329 Views)
Sorry I am not using TCP, this is low level packets below the IP level.
Message 3 of 8
(6,326 Views)
It's still just a bunch of bytes. There is still a protocol imvolved and you will need to format your data according to the protocol you are using. What protocol are you using?
Mark Yedinak
LabVIEW Champion
Message 4 of 8
(6,323 Views)
I am quite happy with formating the bytes I need. There are a couple of protocols I am dealing with LLDP multicasts is the well known one, type 0x88cc. What I need is where to put my bytes of data to send the packet.
As I said the winpcap library is the only option I have found, and I am looking for either something better, or any update information on how to use the 0_6 alpha version of the library.
David
Message 5 of 8
(6,315 Views)
Using Winpcap library i am able to receive data packet from the device but i am not able to send any raw packet to the device. If someone have experiance on sending raw packet please share with me.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 6 of 8
(6,246 Views)
Well as no one came up with anything better here, I pressed on with the 0.6 version of the code I linked to before.
http://forums.ni.com/ni/attachments/ni/170/184448/1/WinPCap%20Labview%200_6.zip
I have used it to send packets, and it works, so my thanks to the original author.
I am still suprised there is no cleaner way of doing this.
David
Message 7 of 8
(6,236 Views)
Thanks for posting this. I have been looking for this code for what seems like forever.  Works perfect for my application.
Message 8 of 8
(3,996 Views)
