windows registry write
I need and example of how to write a value to the registry using labview 7. The help for the vi doesn't make sense to me
[HKEY_LOCAL_MACHINE\SOFTWARE\MYAPP\DATA]
@="A5A5A5A5A5A5A5A5A5'
Thats what i'm tring to write into the registry.
(3,417 Views)
Try this example.
Regards
Ray Farmer
Regards
Ray Farmer
(3,418 Views)
Hello Ray
I tried to use the vi that you attached (Simple_Write_to_Registry.vi )  but i can't use it with DWORD datatype.
Can you explain me how to write DWORD to the windows registry ,itws very urgent.
Koby_A
(3,280 Views)
@koby_a wrote:
Hello Ray
Right click on the VI "Write Registry Value Simple.vi" and select Select Type->Write Registry Value Simple U32.vi or simply wire a U32 number to the data intput of that VI.
But your original example @="A5A5A5A5A5A5A5A5A5' definitely wasn't a DWORD. A DWORD only can go up to 0xFFFFFFFF and usually is not eclosed in double quotes.
Rolf Kalbermatter
Message Edited by rolfk on 04-04-2006 10:54 AM
Rolf Kalbermatter  My Blog
(3,262 Views)
