windows event
I use LV6.1 and IMACVision, and I need to wait for an event send by an other application (from DLL); Where can I find informations or VI to define (Create, Reset, Kill, Read) events with WINNT 2000 platform.
Thanks.
(3,481 Views)
In LabVIEW 6.1, there is no way to programmatically create, reset, etc. events. The only events that are accepted are events created by direct user interaction.
You will probably want to look into other routes of communication between the other application and LabVIEW.
(3,481 Views)
Sorry, my LV version is 6.0
But with new LV6.1 it seems to be possible to generate an event programmatically, but is it possible to read an event from other application ?
For the other solution, my other application don't work with sending Windows message, so...
thanks.
(3,481 Views)
I don't know if applies to your application, but in case it is possible to transform the external code (that dll) into ActiveX, you can capture it's events (see axevent example in "lv folder\comm\")
Hope I understood the problem
(3,481 Views)
Exact, I will have to developp my own DLL to control windows events and to be call from LV6.0 .
thanks & best regards.
(3,481 Views)
