will LabVIEW supports .ac3 files
Hi friends,
     I have a probelm with Dolby AC3 files...In my application i need to pump Ac3 Stream from the soundcard....
Normally we have an Dolby utility for that....
some softwares like cool edit is pumping AC3 stream without showing any problem...without using the Dolby's Utlity by converting into WAVE File....
But how can i pump the same here in LabVIEW....
Do i need any extra Data Plugin's for this support...?
Do we have any DLL for playing that...?
Please suggest me an optimum way of doing this....
Thanks and Regards,
SODLB
(2,976 Views)
NO,
LabVIEW will most likely never support ac3 files, you should use a dll tot get those streams.
There was a coding challenge for mp3 support but I can't seem to find any solutions posted...
Ton
My LabVIEW Ideas
(2,975 Views)
Thankyou Ton
for your information....
may i know which dll will support that...
where can i get that....
Thanks and Regards,
SODLB
(2,966 Views)
I think Lame supports that...
However that is how far my knowledge goes..
Ton
My LabVIEW Ideas
(2,961 Views)
Thanks for your information TON...
I will just check that...and search for it...
However if you come across any such thing give me reply....
Thanks and Regards,
SODLB
(2,953 Views)
