why why why???
this is my VI please take a look... 😞
Message 11 of 16
(1,042 Views)
I just ran your VI and it returned 1000 points to the waveform chart without any gaps. Is this the same behavior you are seeing?
Sean C.
Message 12 of 16
(1,008 Views)
Are you possibly using the "continous run" button?
Message 13 of 16
(1,001 Views)
Hi... Sean C, altenbach...
The gaps was appear when I press run the VI "continuously". Because in main VI, i putting this subVI and an infinity loop and without timing...
Any suggestion to avoid about this?
with regard
Jaxx
Message 14 of 16
(987 Views)
The button "Run continuously" has no legitimate use outside debugging. It is not a valid way to run a program. Most likely your scan VI reinitializes with each restart.
You should not get any gaps when using the "AI continuous scan.vi" as intended. Check the online help and examples.
(Sorry, I don't have any DAQ drivers installed, so I cannot test any of this).
Message 15 of 16
(970 Views)
Hi, altenbach...
i had tried to check the onlline help but seem like can't help me too. but anyway i still wanna thank you~ 🙂
with regard
Jaxx
Message 16 of 16
(950 Views)
