why does
"Import CVI Instrument Driver" menu selection generate a LLB that has VIs which have not been generated correctly when a VI function parameter returns a ViSession pointer. The only one generated correctly was "initialize", however, "autoConnectToFirst" was not. They both have similar prototypes in the .FP file. When I look at the block diagram of the init VI, there is a "IVI New Session" control, but in "autoConnectToFirst", there isn't. Therefore the session returned in Labview is 0, but the session returned in C (through debugging) is a valid session.
(2,545 Views)
See my comments in your other posting of the same question, here.
Brian
(2,545 Views)
