why does this freq. meas. vi frequently output zero?
I've searched the forums and learned that the 1-counter-low-frequency vi from the digital frequency measurement library fits my needs (roughly 2500 Hz to 25000 Hz signal freq range, DAQpad-6016 device).  I thought all I needed to add to the example code was a while loop with a delay, and a gauge.
But the vi outputs zero fairly often, and I don't see why.  I don't think the input signal is dropping out, so it must be another one of those noobie mistakes I keep making!
I've attached my vi.  Thanks for any insight!
Jeff
Jeff
Climbing the Labview learning curve!
Sanarus Medical
Pleasanton, CA
(2,630 Views)
Your code looked good so I connected a TTL frequency generator and tried it out.  No problems or drop-outs here.  I played with varying frequencies for a few minutes, it worked just fine.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,617 Views)
Thanks for the feedback!  I'll focus on investigating the signal rather than debugging a vi that works fine.
Jeff
Jeff
Sanarus Medical
Pleasanton, CA
(2,612 Views)
