why do i get error 56
WHENI AM DISCONNECT FROM THE REAL-TIME PROGRAM I SOMETIMES HAVE DIFICULTY CONNECTIN AGAIN. I RECIEVE ERROR 56 WHICH SAYS THE NETWORK OPERATION EXCEDDED THE NUMBER OF USERS. THERE ARE NO OTHER USERS ? WHATS UP.
(2,739 Views)
Hi dr. sound,
Error 56 is caused by either the number of users OR the system time limit being exceeded. In your case, when you disconnect, it may be that the system time limit is exceeded. It's possible that your real-time program needs more time than you're giving it to reset and be ready to listen for a connection again. I would check those settings, or wait a little bit before trying to reconnect. Hope this helps!
Jeremy L.
Jeremy L.
(2,739 Views)
