why do I get Error 42 when I build a RT-exe with numbers in the Target file?
ok, I will do a repair of my RT Installation. There seems to be something wrong with it.
Without changes I can also build an executable with it. But then I changed the name to only startup.rtexe, made a build (this worked), changed it back to startup1.rtexe, and the error 42 appeared again...
Thank you very much for your help so far.
Message 11 of 21
(2,077 Views)
Your're welcome. And please post back with if it's not working, and also if it's working (what I hope it will).
Message 12 of 21
(2,068 Views)
I repaired my RT Module, but I'm still getting the Error 42 as before.
Any ideas what else I can try?
Message 13 of 21
(2,057 Views)
Could you try once to set the destination path of your build directly to C:\
Christian
Message 14 of 21
(2,046 Views)
No this also doesn't work.
I also found out that startup is the only acceptable name for a Target filename. I can't rename it to something like application.rtexe, otherwise error 42 occurs again.
Message 15 of 21
(2,034 Views)
I think I was not clear enough with my last suggestion.
In the build settings, please set the "Local destination path" under the Information Category to "C:\"
Christian
Message 16 of 21
(2,029 Views)
Where you able to build it now with the changes suggested my by last post?
Christian
Message 17 of 21
(2,008 Views)
sorry for the late reply, I was in vacation the last 3 weeks.
Building the RT exe under c:\ doesn't work for me. But I think this time the IT of our company blocked me from creating any files on c:\:
Fehler 8 ist bei Öffnen/Erstellen/Ersetzen einer Datei in RTBEP_Generate_Deploy_Instructions2.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller aufgetreten
Mögliche Ursachen:
LabVIEW:  Dateiberechtigungsfehler. Sie haben nicht die erforderlichen  Zugriffsrechte für die Datei.
C:\depinstr.bin
Message 18 of 21
(1,914 Views)
C:\ is not necessary.
We just want you to specify a "short" build path, so the whole path should not have more then 99 characters.
Can you test this?
Christian
Message 19 of 21
(1,909 Views)
I tested and it almost works.
I changed the path to something like C:\RTexe, and with this path I can build my RT executable with any name I like (with numbers, whitespace etc.).
But here is the caveat: I am not allowed to use startup.rtexe as my target filename. If I build my target as startup.rtexe (this works), I afterwards cannot change the target filename to something else. This always produces the error 42 in the build process (with any name other than startup.rtexe).
A workaround to this problem is to then delete the complete folder C:\RTexe. Then I can again build my target with any name I like.
I hope someone can confirm this problem.
Message 20 of 21
(1,879 Views)
