I'm not using Linux, so this is just a wild guess.
Nowadays, most pc use 32 or 16 bit display mode, while
LabVIEW doesn't support these color depth. So when you
want a 24 bit image, LabVIEW will convert the screen color
depth to 24 bit. To avoid this convertion, manually set
your screen display mode to 24 bit.
If you send me a copy of the data you got from Get Panel
Image, I can at least tell you if the data is right or not.
George Zou
http://gtoolbox.yeah.net
George Zou
