why array output comes 2 slot contain previous count
excuse , hello i am from indonesia
my program using arduino, i collect the data to get standard deviation , so i think i use an array , but im confuse with last  2 slot that always contain last measurement or zero if it never measure before , ty before
(2,678 Views)
Accepted by topic author kucink
Time to bring this up again
DON'T USE BYTES AT PORT!
Do you know you got a complete message?  What is the format that your Arduino sends the data?
A proper communication protocol will send a complete message and end it with a termination character that tells the end of the message has been reached.  Your Serial Configure is already set up by default to expect a termination character of a line feed character.
If your message is incomplete, then when it parses the data, you'll get an error or nothing with will be interpreted as a zero.
(2,659 Views)
thanks for replying
if i not use bytes at port , im trying not to use it then the program dont run ,
my arduino send string data then i parcing it to get 4 input data analog from potensio resistor
mr ravens can you give me a program or refrence for my program , ty for the advice
(2,589 Views)
@kucink wrote:
thanks for replying
What do you mean by "dont run"? If you're using the println function, your Serial writes will end with a LF character. (e.g. if your code is "Serial.println(mydatavalue)" )
When you use the Match Pattern node you're splitting the string at each letter and then just ignoring parts of the string (because for example, the output at the B node will be "1023.00C1023.00D1023.00"
Consider using something like Scan From String Function instead (or Match Regular Expression with subpatterns).
Here's an example that removes the Bytes at Port:
Read a large number for the "VISA Read" to ensure the reason for a complete read is a complete line (not fixed number of characters).
GCentral
(2,581 Views)
thank you so much
the program running by changing visa flush io with visa set io and delete property node
thanks i will read more and ask more
thanks mr ravens
(2,569 Views)
