while-loops nested in while-loop
Hi! I'm new to labview and I've got some problems. I want to program a control for a testing facility. therefore I want to program several while-loops  nested in each other, according to a designed Nassi-Shneiderman-diagram. So if the stop condition for an inner while loop is true (e.g. measure device mistake), the program should jump out of that while loop in the next outer while-loop. is that possible?
Thank you right now!
(3,913 Views)
Yes it is possible
When you stop the inner loop, from inside the inner loop, just wire/pass an appropriate stop condition ( stop if true/ continue if true) to the conditional terminal of the outer loop
keep cascading this for all outer while loops
Hope this helps
Dev
(3,910 Views)
