while loop inside event structure
I am using a simple while loop in an event structure.
The problem is that i am not able to stop the while loop by stop button.
(4,663 Views)
Because you have the properties for the OK button value change event set to lock the front panel until the event completes.
I suggest you search the forums for message threads dealing with while loops and event structures.  I'm sure you'll find your question would have been answered hundreds of times before.
Your code is inside out.  In general, don't put a while loop or any code that takes a long time to execute inside an event case.  The event structure itself should be inside a while loop.
(4,659 Views)
I also strongly recommend to read the Caveats and Recommendations when Using Events in LabVIEW.
(4,626 Views)
I have read you question perfectly & solve it. but I can not excess your due to your higher version of LabVIEW than me. So I attached here my logic to you. To event structure simply enter the any timeout value then you will able to stop the while loop by stop button. I hope you get your desire answer.
Thank you
Vinal Gandhi, CLA
(4,622 Views)
That code makes absolutely no sense.
(4,606 Views)
Hi shrekt,
  Just you need to uncheck the option  "Lock front panel untill the event completes" (this option will beat the bottom of edit events)  andthe code will work fine.But always dont try to put while inside a event structure(good programmng practice).
Thanks and regards,
srikrishnaNF
Srikrishna
(4,590 Views)
Hi guys,
Thanks for replying,
I got the logic changeto avoid any other problem.
Shrek
(4,582 Views)
