while loop in for loop
hello,
i have a problem with the following:
it starts and doesnt end. only the first "m" and "b" gets inside the while loop. afer "=" there is false. Why is this while loop standing still?
Message 1 of 8
(4,313 Views)
How do you know it is standing still ?
What if it can't find a true, how do you stop it ?
Message 2 of 8
(4,303 Views)
The stop condition is that your number has to equal zero.  You did not get a zero so the loop does not stop.  You could try less than or equal to zero for a stop condition.  Put a probe on the number feeding into your condition.
Message 3 of 8
(4,302 Views)
ok, that could be the reason.
Good idea with the less than or equal to zero for the stop condition.
But this would only function, if the line-value begins with a value/values less than the values of the comparing array.
So i have to set a case structure for this i think.
Message 4 of 8
(4,289 Views)
You could also make it without a while loop:
Message 5 of 8
(4,287 Views)
One thing to note about the above code. If the input arrays are not the same size the loop will only run a number of times equal to the length of the shortest array. If an empty array was input the loop would not run.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 8
(4,281 Views)
You can also use the in range (on the comparison palette) and define the upper and lower limits of when you want it to stop.
Message 7 of 8
(4,280 Views)
this code looks nice. instead of searching for the 0 i could square the values in the array and search for Min.
I will try this tomorrow. I think there are some other mistakes in my vi on top, because "array with x values" and "array with indizes" (the lower lines) are on 0 when the program runs and nothing varies. But the first point has the coordinates y=0, x=90.
edit: the arrays have the same length.
Message 8 of 8
(4,269 Views)
