while loop execution order
Guni,
Thank you for posting more information and the example code. I understand quite well now. I have attached my answer as a state machine. This will be the best thing for what you want to do (multiple sections of code in a predetermined order, but unknown number of times).
Randy Hoskin
http://www.ni.com/ask
Message 11 of 13
(970 Views)
Randy,
sorry, your solution is really good, but it doesn't work in my case, because some of my loop - actions include dialogs with the user. And while one of this dialog-including loops is waiting for the answer of the user all the other loops still have to be executed.
Message 12 of 13
(970 Views)
If you add a separate 'actions' loop to the state machine example then you can execute actions which dont halt the main execution loops. You do need to use a few local variables though.
I've included 2 examples. The first has one action loop, and only allows one action to be taken at a time. The second has 3 action loops which allows all 3 actions to occur at the same time (although the one button dialog does not show 3 popups as it is not reentrant).
I hope this helps you.
Kim
Message 13 of 13
(970 Views)
