where is the mathscript node and window in LV9
I'm working through the 6 hour introduction to LV8.6, but was required to download LV9.  There seems to be some significant differences.  One of which I cannot find the mathscript node and likewise the mathscipt window necessary to work through lesson 4.2
tutorial reads: 4. Place down a LabVIEW MathScript Node (Programming»Structures»MathScript Node).
I found a matlab node and formula node but neither seem to work. Also the tutorial reads:  Open the interactive LabVIEW MathScript window (Tools»MathScript Window…).
Dont see that anywhere either.
Finally on another note.  I was unable to save output files to multiple files.  Seems the dialog box to select this option in version 9 does not actually save the setting. After I click ok a return nothing has changed.  I'm wondering if this is a evaluation limitation.
Thank you,
e
(2,526 Views)
There were several threads about Mathscript when 2009 was first released and not to stir up another hornet's nest, but with 2009, you need a separate license for it and it is no longer included.
What option are you talking about for multiple files?
(2,520 Views)
I found it it is a bug in 2009. Here's the message:
 Unfortunately, there is a bug
(CAR 179472) within LabVIEW 2009. This is something our R&D department
knows about and is scheduled to be fixed with the next update disks
(LabVIEW 2009 SP1). I apologize for this. Are you simply working through
the exercises or are you planning on using it for your application?
(2,491 Views)
