where is data acquire window in labview7 ?
hy.
Before i work with DAQ6024 & Labview 6.
Now i try Labview 7.1 and i don't find     data acquire window.
I cant see a simple temperature data  (from daq) on a numerik deck !!!
Where are tools to work with a traditional daq (or virtual instrument) ?
Where are for exemple: AI.acquire waveform.vi , AI.acquire signal.vi , AI send signal or make signal   ???
I find NI daqmx global channel   but i cant extract a signal without    data acquire   tools ...
Perhaps i dont take good way...
With labview 7.1 pro,  how i can do to acquire a    temperature (from daq sensor) and see    on a numerik deck    or  waveform graph ?
I try uninstal, instal, labview6, labview7, nidaq7, max3.0.1,  all work fine (test panel is ok in max3.0.1 sensor work fine), but no  "acquire tools" in labview7 diagram functions palette...
(2,867 Views)
Looks like you have not installed traditional DAQ device drivers
The latest version, you can download here
http://digital.ni.com/softlib.nsf/websearch/3DBF3D343476A28F8625709E006A4937?opendocument&node=132050_US
Bu, I suggest that you use DAQmx Measurement VI's. Your 6024 is supported by DAQmx Device drivers also
this link will give you an Introduction to DAQmx functions. Try them out
(2,861 Views)
hy  devchander.
My mistake :   during instal of devices drivers:  path labview7.0 (default) instead of labview7.1
And with Nidaq741 at the end, all my tools   data acquire  is in Ni mesurement.
(2,842 Views)
