where can I download labview 2013
I hope I am on the right board.
I am looking to download labview 2013 because I lost my media. I was not able to find where the old versions of labview are kept after many days of searching online. Is it possible to download previous version of labview?
Thanks.
(9,137 Views)
Days? The top two results on google when you search "LabVIEW 2013 Download" are the 64bit and 32bit downloads.
Now you do need to be logged in to your account in order to download and the version needs to be a version that you have paid for in the past or that your SSP covers.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(9,135 Views)
I have always thought that was just for the SP1 and not including the original software. I will register my serial and see if I can download as my SSP has expired.
Thanks.
(9,129 Views)
Nope, should be the whole thing. The hard thing to find is LabVIEW 2013 original release without the SP1 improvements. Though I don't know who would want that.
Cheers
(9,124 Views)
Well, I registered my serial and all, and then went into my account > My product and clicked on access previous versions. There are a bunch of packages and run-time engine, but the software itself is not in there. Anyone know of any other way to navigate this confusing process of being able to download labview 2013?
(9,047 Views)
Hi LabVIEWNoob16,
Sorry to hear this has caused you so much trouble!
To clarify, LabVIEW 2013 and LabVIEW 2013 SP1 are two separate development systems.  If your serial number is only for LabVIEW 2013, you will not be able to activate LabVIEW 2013 SP1.
Also, without SSP, you will not be able to download versions of LabVIEW prior to 2013 SP1, (such as 2013) from the NI website.
However, since you've already purchased the software, we should be able to get another copy of that software to you.  I'd recommend reaching out to your local NI sales representative to open up that conversation.  You can search for your representative by location and focus through the following link:
http://us.ni.com/contacts/local-sales
Best,
David Randolph
Applications Engineering
www.ni.com/support
(9,026 Views)
