where can I down load zlibinflate
where can I down load zlibinflate_ogtk.vi from, does anybody have it? Tried VPIM, but IT firewall will not allow a internet connection..
Any hekp would be greatly appreciated.
Message 1 of 8
(5,062 Views)
Find the attached.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 8
(5,056 Views)
Thank you for the quick response, it looks like the folder I need, however an vi appears to be missing. This is the build error cluster_ogtk.vi. I have put a png as an attachment.
Message 3 of 8
(5,043 Views)
Accepted by topic author SSB01
Here you go...
Message 4 of 8
(5,031 Views)
Thanks for the help, you are a star..;)
Message 5 of 8
(5,022 Views)
One questions.. the VIs can't run because of "Call library founction node: library not found"?
Where can I download the lvzlib libraries? Thanks.
Message 6 of 8
(4,517 Views)
Are you using LabVIEW 64 Bit for Windows? The current official version on the VIPM network only supports 32 bit LabVIEW versions.
Rolf Kalbermatter  My Blog
Message 7 of 8
(4,507 Views)
Yes, using LabVIEW 64bit. Any unofficial releases available to try?
I need to decompress a http reply string with "encoding:deflate". Appreciate any advice how I might go about decompressing the string. Thanks.
Message 8 of 8
(4,494 Views)
