when is shared variable updated?
A boolean network-published shared variable "No Emergency Stop" is bound to a control and inverted in the error detection vi then passed to the operator interface vi for display via a single-process shared variable called "Alarm". Distributed System Manager verifies "No Emergency Stop" is read as true. When I run the top level vi, the operator interface vi opens and displays "Alarm" as true. This is not what I expect it to be, so I open the error detection vi while running. As soon as I open it, "Alarm" goes false. What is happening here?
(2,707 Views)
My experience with published SV's is that you have to "run the node" once before getting the expected reading out of it. I remember reading something about this as well, but I can't find it right now. I'll repost if/when I find it.
At any rate, on the last system (RT) where I had several NP SV's, I had an intialization VI which wrote and read dummy data before I read the SV in the main program. That worked for me.
Richard
(2,696 Views)
