when i run application.exe each vi opens in different windows.
Hi
In my application i have multiple vi's.
main vi calls other vi.
when ever main vi calls other vi each open in different window not the same window/one window.
how to make all the called vi's open in same window. not separately.
Thannk you
Hari
(2,235 Views)
Well in LabVIEW each VI has it's own front panel and each front panel is (by default) a window. I you want to have only one window in your application but want to display the front panels of some other VIs than your main VI, you can use subpanels.
Hope this helps
Epictetus
Antoine Chalons
(2,232 Views)
