when do we close reference?
I am confuse as to when do we close reference in LabView. I tried to close the references that I have in one of my VI, but somehow the VI will not run altogether. So when is the right time to close a reference? Is it after we get done with a method or property or when when we are done with the whole class? Thanks.
(3,507 Views)
Check out this link. Read what Greg Mckaskle says.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000834C0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=closing+references&USEARCHCONTEXT_QUESTION_S=0
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,507 Views)
analog;
Check the following article by Dr. VI:
Control References in LabVIEW 6.1 (and earlier): When Should I Close Them?
Regards;
Enrique
www.vartortech.com
(3,508 Views)
did i need to close refernce that is generate from VI property node frome the upper left corner of the connector pane?
(3,484 Views)
Hi Yonatan. You don't need to close that reference, because you didn't explicitly open it. LV opens and closes these references automatically (I hope so, anyway. Otherwise, I'm in serious memory problems).
___________________
Try to take over the world!
(3,480 Views)
