whats this Error?
Could anyone help me and tell me what is this problem?
(3,468 Views)
This is now an example of an error message that EXACTLY tells you what the problem is. Check the way you define the path. Nothing else.
Cheers
Edgar
(3,464 Views)
What is the path you are passing into this VI?  I can't tell since the data going into the subVI is blocked.
And you really should be passing your errors along and handle then in some way other than letting the automatic error handler do it.
(3,437 Views)
check this out please. I solved that problem, I forgot to connect path file:)
(3,434 Views)
That is usually an invalid reference being used/created.  I'm not familiar with IMAQ, so I don't know what you code is trying to do.
(3,425 Views)
