04-11-2001 03:34 PM
04-11-2001 05:00 PM
04-11-2001 05:12 PM
12-07-2008 03:45 PM
abrause wrote:
Allison,
If you are using LV5, installing just lvrt.dll in the system (or system32)directory will
work. Be sure to put serpdrv in the same directory as your executable, though.
What file format is serpdrv? Is it DLL or what?
I wish to make my executable work on computers that don't already have Labview installed, and this sounds like the key. However, if I am to find these files on a computer that has Labview on it, I'll need to know what folder it's under. Where are they?
On a similar note, why when I built the executable (something.exe) does it also make 2 other files (something.ini and something.aliases)? I never told the compiler to make those files, and my programs are all VERY simple so far so I don't need any ini files. If I did I'd use the ini file making block in Labview (you can add several different types of file making blocks you can add to your block diagram, including one for ini files).
12-07-2008 06:17 PM
You've used a very old thread to post to and though you don't mention the version of LabVIEW, it has to be at least 8.0 since the builder is creating an alias file. Since it's 8.x, the serpdrv is not at all relevant. That is a very obsolete driver for serial communication.
The key is really to create an installer after the exe is built. It will include the LabVIEW run-time, support DLLs, and any hardware drivers that you choose to include.
The ini file will always be created when you run the exe. It has the same function as the LabVIEW.ini file
