what should be architecture to sample 12 channels at FPGA to maximise rate
Hi I'm building a datra logging tool based on FPGA
I'm sampling about 12 channels, on three C-Modules.
also 1 being a digital one to measure RPM.
I want to know what is best way to maximize sampling rate..
currently I sampling each channel in different while loops and then updating their respective variables.
However I saw an example
https://forums.ni.com/t5/Example-Code/Transfer-multiple-channels-of-data-through-one-DMA-FIFO-on-FPG...
on NI site that sample all channel under one while loop.
when I tried the sampling was real slow.
thanks in advance
mudit
(3,145 Views)
Wow difficult to grasp functionality of your png.
Suggest you read the tutorial:
https://www.ni.com/en/support/documentation/supplemental/09/ni-compactrio-waveform-reference-library...
Have utilised example to monitor and log 10 channels .
xseadog
(3,105 Views)
thanks I guess this should do the job!Smiley Happy
(3,097 Views)
