what is the maximum rate we can achieve using 9403 in digital switching
what is the maximum rate we can achieve using 9403 in digital switching?
 i am using 9102 chassi and 9012 controller.
 i am trying to program the 9403 as the output port and i am using it for switch on one of my devices.
                      minimum pulse width should be =1micro second
(2,450 Views)
Have you looked at the specifications in the user manual for the 9403?
http://www.ni.com/pdf/manuals/374069e.pdf
Looks likethe update rate for the 9403 using a cRIO 9102 chassis is 7microsec.  I don't think you can get 1 microsec pulse width using the 9403, maybe try the 9401 or other high-speed module.
Dan
(2,443 Views)
