what is my variable?
See what I mean?
#define fits_write_key_longstr ffpkls
#define fits_write_key_longwarn ffplsw
#define fits_write_key_null ffpkyu
#define fits_write_key_str ffpkys
#define fits_write_key_log ffpkyl
#define fits_write_key_lng ffpkyj
#define fits_write_key_fixflt ffpkyf
#define fits_write_key_flt ffpkye
#define fits_write_key_fixdbl ffpkyg
#define fits_write_key_dbl ffpkyd
#define fits_write_key_fixcmp ffpkfc
#define fits_write_key_cmp ffpkyc
#define fits_write_key_fixdblcmp ffpkfm
#define fits_write_key_dblcmp ffpkym
#define fits_write_key_triple ffpkyt
#define fits_write_tdim ffptdm
#define fits_write_tdimll ffptdmll
#define fits_write_keys_str ffpkns
#define fits_write_keys_log ffpknl
#define fits_write_keys_lng ffpknj
#define fits_write_keys_fixflt ffpknf
#define fits_write_keys_flt ffpkne
#define fits_write_keys_fixdbl ffpkng
#define fits_write_keys_dbl ffpknd
Message 11 of 15
(720 Views)
Not really. What is that supposed to show? All I see is a bunch of defines. Are those of a specific datatype? If you're using some sort of enumeration inside your framework, then all you need to do (if you use the OpenG function) is to convert the enum from one value to another value, the latter matching the enumeration inside your framework. A simple case structure in the LabVIEW code would accomplish this.
Message 12 of 15
(710 Views)
Yes, each one is for a specific data type. Fortunately, I only need three: string, int and float.
Message 13 of 15
(705 Views)
OK. So, have your questions been answered, or are you looking for something else?
Message 14 of 15
(699 Views)
I think so. Thanks.
Message 15 of 15
(694 Views)
