02-21-2006 12:24 AM
hi
i am doing some data acquision work in labview..i want to know that for data storage which will be better , microsoft excel or labview measurment file.. whats advantage &disadvantage of same
02-21-2006 12:46 AM
Epictetus
02-22-2006 05:48 AM
Thanks for suggestion..as you can find out i am new for labview so i may need your suggestion further also
actually i want to store the signal for further analysis purpose..so that if need come then i can read from file &convert them in signal form again.
i also want to open that file on another system which is not having labview installed
02-22-2006 07:10 AM
There's a lot more overhead saving directly to an XLS file, if that's what you're talking about doing.
Since an LVM file is essentially a text file with TAB or comma delimited values with some additional header information (still just plain text though), it's very easy to open it in Excel and have it put things in the proper rows/columns.
