what files are installed with web only labview 8.0.1 runtime
I am getting ready to deploy a program at our factory.  The program will allow for remote panels to be used.  There are a few computers on the floor that need to have this configured.  In order to view the remote panel, I need to install the compact version LV runtime (only 24 mb instead of 87 mb on the NI website).
The problem is that they are running citrix pcs instead of standard pcs.  I am currently working with the IT dept to see if it is even possible to install the run time on the computer.  But even if it works, our IT manager wants to be able to roll back the install if it "breaks" something.  So I was looking for a list of all the files that it installs on the computer, so that they can be deleted manually (what I got from the IT manager is that it does not have a standard uninstall process).
Kenny
Kenny
(2,518 Views)
i solved it by going on a fresh computer and installing the run time and seeing waht files were modified today and then manually entering the list inot word (since you can only copy the file name and not the location in a search)
Kenny
Kenny
(2,512 Views)
