what does the error code -41004 mean in print report.vi?
I am getting the following error in the Print report.vi.
Error Code : -41004
Error Scource : Print Report.viPrint_VI_Image.vi
(7,232 Views)
I have done a fairly extensive search and haven't been able to find out information on that error. The description of the error states "NI-Reports: Print error". Elaborate a little on what you are wiring to this block. I assume you have a printer installed on this computer. Are you leaving the printer terminal unwired?
(7,232 Views)
Hi
I have attached the main vi which is using the NI-Print Report.vi.
I have also attached the image of the error desciption I got.
(7,232 Views)
I got the same error message.  In my case, my printer was not set up as the default printer.  I got the same error when I turned the printer off and tried to print from my VI.
(6,755 Views)
