what URL's does datasocket use?
I've just found yet another URL type used by datasocket. Has anybody seen a COMPLETE list of the acceptable URL's for datasocket and which types require datasocket server to be running?
(3,306 Views)
Hi Philip,
Since datasocket consists of four basic actions (open, read, write,and close) that are similar to standard file I/O calls, you can use the same DataSocket API in your programs to read data from:
� Data items on HTTP servers
� Data items on FTP servers
� Local files
� Data items on OLE for Process Control (OPC) servers
� Data items on DSTP servers
If you need more information, there is a nice "DataSocket Technical Overview" white paper on the ni website at : DataSocket Technical Information
Hope this helps,
Pravin
(3,306 Views)
OK
what about logos:// and lookout:// url types. These are not related to the connection points you have about. Is Ni going to relase a proper manual detailing the hidden technologies in Datasocket?
(3,306 Views)
My bad, I missed out on logos.
NI did expand DataSocket to support Logos.
You can find the updated URLs with a latest version of datasocket help or in the help files of labview 6.1 under 'DataSocket URLs' on the 'Valid URLs for a DataSocket Connection' page.
It doesn't list loookout there since it uses the same logos protocol. You could either address as
logos://computer_name/process/data_item_name
or replace logos with lookout and you are still referring to the same data item using the same protocol.
Pravin
(3,306 Views)
