weird characters
here you go,
Message 11 of 20
(2,242 Views)
That is not a .csv file.  It is still an .xls file that you just happened to give the .csv extension to.
Did you remember to change the type of file you were saving to when you used the Save As dialog box in Excel?
Message 12 of 20
(2,236 Views)
ok got it. i got what i wanted
but why is there such a problem in the first place ie. the weird characters if the file is not in csv format??
Message 13 of 20
(2,230 Views)
Ugh, really?  If you don't understand this basic concept, I'm not sure you'd understand the explanation.
Bill
CLD
(Mid-Level minion.)
Message 14 of 20
(2,224 Views)
Here is what the file contents look like when read as a binary file and displayed in hexadecimal.
A real csv file would have most of the hex characters starting with 3.
Lynn
Message 15 of 20
(2,216 Views)
Accepted by topic author ybomi
The Read From Spreadsheet File reads text files that have a delimiter of some sort.  Common delimiters are tab and comma.  An XLS file is a proprietary format the Microsoft created.  Only parsers that specifically know the xls (or xlsx) format.  The Read From Spreadsheet File does NOT know this proprietary format.  That is why it doesn't work.
Message 16 of 20
(2,184 Views)
thanks crossrulz, now i understand.
My bad that i did not understand fully
Message 17 of 20
(2,167 Views)
In your own defence an Excel file is a spreadsheet.  just one in a propriatary format that contains bytes and bytes of specific constructs.   There is even a romur that an easter egg exists in Excel with an entire plane flight simulator.  A "Generic" Spreadsheet is all that read from spreadsheet file supports.
"Should be" isn't "Is" -Jay
Message 18 of 20
(2,160 Views)
thanks so much guys =D
Message 19 of 20
(2,152 Views)
Not sure about the current versions of Excel, but it is true that the earlier versions had a basic flight simulator. And when you consider that memory in a PC was limited to 640Kbytes!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 20 of 20
(2,128 Views)
