weird behavior of cluster
Hi all:
I'm using a cluster in a front panel to get some info from the user.
Later, some values are obtained from this cluster using a local
variable. The problem is that always the last value in the cluster is
lost. The cluster is made of 6 string controls and if all 6 are filled
up in the front panel, only the first 5 have data. Weird uh?
Any idea of what is happening?
(2,649 Views)
Have you checked for race conditions? Perhaps your local variable is getting data before you write it all. This is a common problem when using local and globals. The best option may be to use a wire to pass data along, and avoid the local if you can (or want).
Hope this helps
(2,649 Views)
