05-22-2007 12:50 PM
05-29-2007 07:29 AM
Hi laser81,
Thanks for posting your query on the National Instruments forums.
If you are new to LabVIEW then I would like to strongly recommend that you consider pursuing the LabVIEW Basics courses. The LabVIEW Basics 1: Introduction course is part of a series of courses designed to build your proficiency with LabVIEW and help you prepare for NI LabVIEW certification exams.
The courses offer:
The most efficient way to learn LabVIEW
Training courses for new and experienced users
Hands-on training with experienced LabVIEW instructors
Basics courses to help you get started quickly
Intermediate courses to help you learn how to optimize applications
Advanced courses to help you learn advanced features and architectures
The context help for linear fit VI in LabVIEW version 7.1 states:
Finds the line values and the set of linear coefficients slope and intercept, which describe the line that best represents the input data set using the least-squares solution.Finds the line values and the set of linear coefficients slope and intercept, which describe the line that best represents the input data set using the least-squares solution.
The context help for linear fit VI in LabVIEW version 8.2 states:
Returns the linear fit of a data set (X, Y) using the Least Square, Least Absolute Residual, or Bisquare method
If you then click the detailed help link in the context help window it will fire up the LabVIEW help document file where the help file explains the differences between
I have attached the help file to this forum. Have you considered upgrading to the latest release of LabVIEW? It is jam packed with even more technology.
Check out the release notes for more information on what’s new with a particular release. Please goto www.ni.com/manuals
I have also found a similar discussion forum link that might be offer some help on the issue this explains a programmatic approach to curve fitting using low level VI’s in LabVIEW.
http://forums.ni.com/ni/board/message?board.id=170&message.id=181569&requireLogin=False
I hope this helps
Best Regards,
Kirtesh Mistry
05-29-2007 07:34 AM
05-29-2007 12:08 PM
I think you meant fitting VIs. 😉
@Kurt NI AE wrote:
in the help file attached goto Context menu > VI & function reference > mathematics VI's > filtering VIs > linear fit
05-30-2007 03:46 AM
