webcam without vision
Hello everybody,
I'm using the .vi suggested here :http://forums.ni.com/t5/LabVIEW/acquiring-a-webcam-image-without-vision-toolbox/m-p/846420/highlight...
and it work fine, I was wondering if it is possible to acquire a screenshot whenever needed by adding something to this code. I need to acquire screenshot a couple of times while the .vi is running and I need to save these screenshots in image files (one file for each screenshot). Any suggestion?
Thanks!!!!
(4,065 Views)
Hello Elena_vsc,
I have a couple of questions if you do not mind answering them.
Are you are referring to Snapshot_Example_LV71.zip or to WebCam_LV71.zip ?
Do you want to acquire these screenshots at certain intervals (i.e. once every ten seconds), at an event occurring or once an operator has pressed a button?
This link gives a good example on how to convert your image into an object on your clipboard for later use, however, a little more information on your application would greatly help us figure out the best way forwards.
Mark W
National Instruments UK & Ireland
(4,007 Views)
Example using a webcam and IMAQdx NI Labview module can set the delay time
http://www.youtube.com/watch?v=aJCxJLuAhTs
(3,894 Views)
(3,886 Views)
