web publishing
HI
i am trying to publish a VI in labview ,when i publish using the  webserver applications i can see it on my browser on the  local compurter but when i try to acess  the  url  i am not able to acess the vi , the vi is not diplayed  , is the webserver not working i am not sure but i am able to acess the webpage
need help
(3,160 Views)
Do you get any errors when you attempt to launch the web server application? Does this behavior only occur on a deployment machine (not on the development machine)? And what version of LabVIEW are you using?
Answers to these questions might help find the culprits of your issue.
Cheers,
Emilie
(3,138 Views)
hi
the web server application is working , and i am using labview 8.0, on a different computer when i got working  i am able to start the webserver , but when again i load the page it says invalid ip adress ,  i dont know what is happening please help
(3,133 Views)
Sounds like the Web Server simply has not been enabled. Or perhaps the html file is not saved in the location it is expecting.
Cheers,
Emilie Kopp | Applications Engineer | National Instruments
(3,110 Views)
