web publishing problem
Hiya,
I'm trying to publish a front panel onto a webpage in explorer. When I type in the link given by the web publishing tool I get the follow explorer error: - "IE has encountered an error and must close. Sorry for the inconvience."
I only get this error when the VI is running. If it is not running then I can see the front panel in explorer.
Any ideas?
Cheers,
Rich
(3,165 Views)
What operation does your vi perform?? Data acquisistion?? serial communication??
did you ty this?? create a simple vi like continous graph updation and try publishing it
If this works, your IE is working fine and the problem can be attributed by your vi
(3,155 Views)
the VI is just manipulating some data which is got through a datasocket connection.
I tried a simple VI and this did work okay.
Does labview not like publishing to explorer if the VI has to communicate elsewhere? Is there a work around?
(3,151 Views)
