web browser activex control could not be loaded in compiled exe
Hi everyone.
I just met this issue again. Previously I solved this issue by registering the mscomctl.ocx, nicont.dll, nicontdt.dll in version 7.1. Now we are using 8.5.2, and the problem came up again.
I've tried the following:
1. use the latest nicont.dll,nicontdt.dll on the installed computer. http://digital.ni.com/public.nsf/allkb/4B0C1BBDA9CFEBE7862573D0005D93C4
2. tried to repair the run-time engine.
knowledge base http://digital.ni.com/public.nsf/allkb/5F06D38D61D883498625734800620168?OpenDocument
How do we enforce to repair the run-time engine of 8.5.2?
Thanks for any input.
Jun
(3,221 Views)
The instructions on the knowledgebase are correct. You need to open Add/Remove Programs and then select the entry for National Instruments Software and click change or modify (whichever option is present for you). You can then follow the knowledgebase and select your run-time version.
-Zach
(3,205 Views)
