wdapi900.dll error on windows 7 while running labview 2010 executible
I don't think wdapi900.dll is a National Instruments software. Where did you get that? Did you check that it is fully supported under Windows 7?
Obviously this wdapi900.dll is either not present in a path that the system can find or it is trying to load other dll's somewhere that are not accessible. It could also be trying to access a kernel device driver that is not Windows 7 compatible.
error 2 is just a logical error from the first one, since all the VIs that access that DLL can't be executable and cause such a message. So find out where wdapi900.dll is from, if it works for Windows 7 and if it does how to install it on your system that it works for applications that make use of it.
Rolf Kalbermatter  My Blog
Message 11 of 11
(452 Views)
