waveform output interval indicator
Hi!
Thank your for this community technicians because I really depend on you.
I created a program where i need to make an interval hitting. The interval is measured by a distance sensor. My program works upto this point. But I failed on hitting command.
So I simulate the acquisition and make the hitting command an LED (boolean). It should also count the number of blink it made.
Attached is the program. Thank you.
(2,860 Views)
What does "hitting command" mean?
(2,830 Views)
I will instruct my solnoid device to push and pull after 1 second.
(2,805 Views)
