Greetings!
I understand your question fine
🙂 There are a couple of things you want to do. First, you might just try a different INTERPOLATION. The graph pallette gives you a few choices in this regard, the default is linear. If that doesn't work sufficiently, you want to try waveform averaging. Depending on how many points you average, you can eliminate "local" peaks while retaining longer peaks. There is a Waveform Average vi. in the NI code archives..(I think it's the one I submitted myself a while back!) Keep in mind that when you average a waveform, your peaks will be offset by half of the averaged samples....no way of gettin around this without "cheating". Hope this gives you some ideas. And yes, this can be done in Matlab quite nicely, and t
here is probably already a waveform average in the Matlab Tools.
Goood Luck
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
