waveform data type definition in C
Hello all,
I'm trying to build a DLL that emulates an acquision card in labview, returning a WAVEFORM data type. This way, I can substitute easily the "AI read" VI of the real DAQ (a 6052E card, actually) with my custom VI that generates a waveform in the same way the real "AI read" does.
I have searched the forums and most answers point to build the waveform cluster in labview from the array of samples returned by the DLL, but I would like to return directly a waveform data type (an array of waveforms, in fact, for all the AI channels). I haven't been able to find the data definition of waveform in "C", but it should be somewhere because you can define waveform as the data type of the parameters of a DLL, and even the DLL of my rea
l DAQ card (lvdaq.dll called within "AI Buffer Read" VI) use the waveform data type as a parameter.
Any help finding the definition wil be appreciated.
thanks in advance,
Adolfo.
(3,240 Views)
You may have seen the HWAVEFORM data type that LabVIEW generates in App Builder when you create a function call to a VI with a waveform input or output. HWAVEFORM is typedef'ed in [your LabVIEW directory]\cintools\extlib.h as a pointer to an IWaveform struct. I don't see the definition of this struct anywhere in the LabVIEW documentation.
However, you could easily add a couple of exported VIs to your DLL that convert raw arrays of double-precision floats (with t0 and delta-t) to LabVIEW waveforms and back. Then, you could still call your custom waveform VI from a C program and then just feed that HWAVEFORM to your 'Waveform_to_Array()' function. These conversion VIs would be trivial to write: basically just wrappers around the 'Build Waveform' and 'Get Wavefor
m Components' nodes.
(3,240 Views)
