waveform charts slowed down control system while loop
Hi
In my application, I have control system which i acquire data, process and output the result. I placed some waveform charts in the while loop where i acquire data, process and output. This made while loop to miss data points( late). Is this because waveform charts store data as time passes?
(2,469 Views)
Waveform charts store data in a history buffer of configurable size. You can change it to a smaller number.
  • What is the size of the history buffer?
  • How many charts are you updating in your loop?
  • What else is happening in your loop?
  • How are you updating them (wire, local variable, value property, etc).
  • How fast is your loop rate?
  • Are your plots simple (thin lines) or fancy (e.g. large dots and thick lines)?
  • Is autoscaling on or off?
  • Are the charts set to "synchronous display" by accident?
  • How many traces are on your chart?
  • What is your LabVIEW version?
  • What is your OS?
  • Do you have overlapping elements on the front panel?
Could you attach a simplified version of your code so we have a better idea what you're actually doing?
(2,457 Views)
