waveform chart
when i plot a signal on waveform chart and set the amplitude range so, it  changes when i drag it with mouse but i want it to remain fix even if i drag it with mouse . any suggestions ? i am stuck with it.
(4,667 Views)
Hi Shaun,
set the Y range using property nodes of the chart back to your "fixed setting" whenever they change…
(Or prohibit mouse dragging for the chart content. 😉 )
(4,648 Views)
how can i  prohibit mouse dragging for the chart content?
(4,607 Views)
Accepted by topic author shaunmarsh123
Hi Shaun,
you could filter mouse events.
Or you could place a transparent decoration on top of your chart…
(4,604 Views)
... Or you can make a filter event for Mouse down? on the chart, checking the active tool. So when active tool is the panning tool, discard the mouse down.
(just explaining a bit more detailed Gerd's first hint)
Greets, Dave
(4,598 Views)
yeah it works fine.. thank you so much 🙂
(4,583 Views)
